Installing shifter cable on a C6? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2008, 10:11 AM
"70" Cougar's Avatar
Meat-Head Extroidenaire
I'm installing a new ratchet shifter on top my C6. In the directions there using one of the supplied brackets for the shifter arm on the side of the trans. Do i have to use their shifter bracket ?, or can i use my stock one. If i must change my bracket then that means i have to undue the bolt from the inside of the transmission because its a stud and not externally held in. Is this normal? As well the bracket that is supplied for me to bolt on to the trany pan has two different size holes... does this make sense? because all the bolts on my trany pan are the same size( all the bolt heads are the same size)
Thanks in advance.
bill C
87 Camaro shifter cable problems davez28 Transmission - Rearend 2 06-18-2007 05:42 AM
adjusting cable shifter william27103 Transmission - Rearend 0 03-05-2006 09:08 PM
