installing a tach on a DIS system - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2003, 10:58 AM
Hollywooding's Avatar
Canknuckle Head
Hey all you gear heads out there in the cyberworld
I have a 94 sunbird LE 2.0 l4 5spd with Distributorless ignition system (no dist, just coil packs)
What the he*k do i install the tach sensor wire to???
Logic tells me that somewhere off the ecm or possibly even already into the back of the instrument cluster i could find a wire there, but this is the first time that new technology has me beat that's for sure
anyway thanks for the help
Hollywooding
EDIT: Just checked the back logs of topics and found that someone had said "off the newer GM's on the ignition control module there should be a white wire to connect to"
Does this sound right to you?
And..... wheres the ignition control module hidden? by the ecm, in the engine bay, boy this new technology is kinda difficult sometimes....
anyway thanks
Hollywooding :cool:
