Installing teflon valve stem seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2011, 06:19 AM
v8hed's Avatar
AK427
I've just tried to install the first of my Teflon seals on my Dart Pro-1 heads... the seal fits fine over the guide (needs tapping on with a sleeve and hammer as to be expected), but I just wrecked the seal when I tried to install the valve... the valve stem didn't want to pass through the small hole in the top of the stem seal and, when I tapped it with a hammer to 'encourage' it through, it ripped-off the top of the valve stem seal!!!! ***!
What am I missing / doing wrong here? I've never known a valve stem seal to be such a tight fit on a valve stem before.
Old 01-21-2011, 06:27 AM
BOBCRMAN@aol.com's Avatar
Install valves in head. Heat the seals in a pan of Hot water. Then carefully install while hot. NO HAMMERS!!!
Old 01-21-2011, 07:47 AM
SSedan64's Avatar
Most of the GM brand Positive type seal kits come with a thin clear sleeve that slips over the Valve stem to protect the seal when installing. They all should but.
.550 valve stem seals...? ForceFed86 Engine 5 09-29-2009 11:05 AM
valve stem oil seals marc737 Engine 1 08-03-2008 04:13 PM
Valve Stem Seals HJCHEVY400 Engine 3 05-04-2004 03:01 PM
Teflon Valve seals Bugsy Engine 3 11-30-2003 07:46 PM
valve stem seals HQ Pete Engine 2 04-02-2002 12:04 AM
