When you install the converter on the trans make sure the pump is engaged. Slide the converter on and then rotate it slowly while pressing on it and it should engage the pump. When it does it will slide on about a half inch further. To make sure its on all the way put a straight edged on the front of the trans and the converter should be recessed a little less than an inch. Also when you bolt the trans up to the engine the converter should still spin freely. If it is wedged against the flexplate then the pump isn't engaged and if you tighten the bolts you stand a good chance of damaging the pump.
Good luck, it isn't as difficult as it sounds.
Centerline
