installing torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2007, 05:45 PM
This is only the second time i have ever pulled my 350 SBC and transmission, and the first time i bolted the transmission back on the engine, i had to take it to a transmission shop. They asked how i bolted the transmission back to the block, and i evidently did not do it correctly, because they said the torque converter broke some kind of gears off inside the transmission. I really don't want to go through that again, so could someone please tell me proper way to put the transmission back on the engine.
Thanks,
plthomp
Old 01-14-2007, 05:51 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
K I S S
The torque converter has a notch where it slides onto the transmission shaft. It will move on part way, stop, turn it, then clunk, then move on some more.
You probably only had it on 1/2 way and when you bolted the trans to the engine, the torque converter pushed the shaft rearward damaging the front pump or gears.
The TC needs to be recessed into the bellhousing about 5/8 inch or so when fully seated.
Old 01-14-2007, 05:58 PM
Thank you for the quick reply, so i need to install the torque converter on the transmission first? That is what i did wrong last time, i installed the torque converter on the engine first, and then twisted the transmission onto the torque converter and bolted the bell housing to the engine.
Thank you for the information, you saved me a trip back to the transmission shop.
plthomp
Old 01-14-2007, 06:02 PM
xntrik's Avatar
Right. It's heavy watch out...... also pour a 2-3 quarts of ATF in the converter shaft hole before slipping it on the shaft.
I'm a big believer of synthetic ATF, but it is $ 6 per quart.. Check with your trans shop for advice.
Old 01-14-2007, 06:05 PM
car builder
Make sure that you that push and turn it,So that it lock in properly.
Old 01-14-2007, 06:24 PM
DeathRattle's Avatar
Some Punk Kid
Do not forget the fluid in the converter. Thats the second most important thing to locating the converter all the way.
Old 01-14-2007, 08:07 PM
tnsmith10's Avatar
when will it rain???
from the looks of things, take it to the trans shop for the install...
Old 01-14-2007, 08:38 PM
Will I ever get it done?
Last journal entry: Hood
It's not that hard. You just have to be careful. You have three things which must be engaged. You have to engage the splines on the input shaft into the driven member of the torque converter. You have to engage the splines of the stator shaft into the stator in the converter. And you have to engage the pump tangs into the notches on the converter hub. Of course, you can't see any of this happen because it is internal. Turn and lightly push the converter until it drops all the way in. Place a straight edge across the bell housing and make sure the converter is deeper into the bell housing than the flex plate extends beyond the back of the block. When you are pushing the tranny to the back of the block, the bell housing should contact the block and the converter should have about 1/8" or so clearance to the flex plate. If the converter touches the flex plate before the bell housing touches the block, STOP. Re-seat the converter and try again.
As a lot of guys already said, put fluid in the converter before you install it.
Old 01-15-2007, 06:14 AM
tnsmith10's Avatar
and make a hell of a mess in the process... u can finish filling the trans once started, since theres fluid still in the bottom of the pan ( nothing said about dropping the pan) the fluid will be picked up by the pump. ull need to add about 3-4 once running... after the installation problem from 1st post, i still say take it a shop...
Old 01-15-2007, 03:17 PM
Ricky Rocket's Avatar
Drive it like a rental!
torque converter installation
The general rule that I recommend is this: if you can fit your fingers between the torque converter and transmission pump, it is NOT installed all of the way. Wiggle, turn, and lightly push converter in some more until your fingers can't fit. This only works on bell housings that are open at the bottom. If it is a full bell housing, you need to measure from the bell into the torque converter and compare to service manual.
Rick
Torque converter question(s) chrisflock Transmission - Rearend 3 11-10-2006 11:41 AM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
Torque Converter Problem? 38project Transmission - Rearend 5 06-05-2005 02:21 AM
torque converter upgrade to avoid detonation? darom Engine 35 05-23-2005 06:48 PM
