installing a trans. shift point adjustment kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2009, 12:50 PM
stanjr41's Avatar
Adjusting a TCI shift-point adjustment kit
For those of you familiar with my 350 turbo shifting problem, this is the consensus final possibility for repair. I have adjusted the kick-down cable,replaced (twice) and adjusted the vac modulator, and am now ready to replace the original transmission governor with an adjustable shift point kit from TCI. The kit comes with a variety of weights and springs. I am a little unsure of how to go about this. The instructions says that this kit will allow me to raise and lower the shift points.BUT; it doesn,t say if it changes the points at a normal acceleration, or when the accelerator is floored.I can live with it at a normal speed shift, but I would like it to down-shift when floored.This is not a simple change, so I would like an idea of how to go about this before I take it apart.
Old 07-22-2009, 01:05 PM
stanjr41's Avatar
I have a 383 chev. with a built 350 turbo. I have been having problems getting it to shift properly.When starting from a stop and flooring the throttle it will rev. to 4000 and shift to 2nd,as soon as it hits 2nd, it then shifts to 3rd.If I am driving slowly and floor it, it will accelerate to 4000 and shift to 3rd.It will never down-shift to first. I have adjusted the kick-down cable, and replaced and adjusted the vac. mod. twice. I bought a TCI shift-point adjustment kit. The instructions say this will allow me to adjust the transmission shift points.It doesn't say if it changes the shift-points at full throttle or normal driving. I would like some kind of idea of which way to go. The kit has an assortment of 6 springs and six weights.They can be used as a pair or separately. This is a lot of choices. Any ideas would be great.
Old 07-22-2009, 04:07 PM
tnsmith10's Avatar
when will it rain???
i would tighten the kick-down cable a bit more and see if it changes anything first. but as far as the govenor goes, the springs affect light/part throttle shifts, the weights affect full throttle shifts.
on the springs, the lighter the spring, the later the shifts under light throttle will be. as far as the weights go, the heavier the weight, the sooner it will shift under full throttle.
just a quick question, with the throttle wide open, is there any slack in the kick-down cable?
Old 07-22-2009, 10:21 PM
stanjr41's Avatar
Please excuse the double thread; I thought the first one was deleted.I have adjusted the kick-down cable so that when the throttle is floored, the cable is pulled tight. No slack or over pulled. I installed a new vac. modulator today and it seemed to help under normal acceleration; the shifts were happening at a later rpm which was an improvement. However it did not help as far as kicking down while cruising at any speed or rpm. It will kick-down from 3rd to 2nd ; but not from 2nd to 1st no matter what speed or rpm. I will try the weights and springs asap. Any suggestion as to which to try first; spring & weight ; weight only or spring only. Small adjustment, mid ?
Old 07-22-2009, 10:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I merged the threads.
basic governor operation and mods is:
the inner springs affect the shift points under 35 mph in light throttle shifts
Inner weights affect shift timing points over 35 mph in light throttle.
Obviously the 35 mph figure moves around some depending on the gear ratio / tire size of the vehicle
If you still still have a stacked shift problem in the 2-3 shift very quickly after the 1-2 shift... look at the cable for fullpull at WOT....
then look at the spring on the 2-3 shift valve in the valve body if you have not added a shift kit or have the v-body appart. This spring has been known to break apart or loose tension.
The Following User Says Thank You to Crosley For This Useful Post:
stea (09-14-2013)
Old 07-22-2009, 11:22 PM
stanjr41's Avatar
I bought the trans. from Summit. It was built by Performance Automatic.It is rated at 550 hp and is supposed to have all the good parts.? It also has a 2500 rpm converter. On the rear of my car, the gears are approx.4.10s. The tires are 25 " in diameter. The kick-down cable is still receiving full pull. With the throttle floored, it shifts into 3rd at 4000 rpm , I would prefer 5-5500 rpm. Crosley; after reading you information,I think I will try 2 sizes lighter of each, than what is in there now. It may be a few days until I can do this so if anyone has suggestions, I could sure use it now! Also thanks tnsmith10; btw; tnsmith10 does your screen name have anything to do with sheetmetal, just wondering, I used to be.
Old 07-23-2009, 05:08 PM
stanjr41's Avatar
The instructions also say to check the fluid level before driving after the adjustment. How much fluid will I lose? Should I use a big or small catch can? I hate surprises, especially with fluid.
Old 07-23-2009, 10:15 PM
stanjr41's Avatar
BIG PROBLEMS! I jacked up my car and crawled under it to change the governor springs and weights. It is impossible to access the cover without dropping the trans. or cutting a big hole in the floorboard. There is absolutely no clearance around the trans. and the tunnel. Unless someone has an alternative plan, I will have to wait until I have a reason to drop the trans. or cut a hole. ANYONE with any kind of suggestion other than shifting gears manually will be my hero. Thanks; Stan
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
4L60E Shift kit. GMCTRUCKS Transmission - Rearend 8 05-20-2012 03:22 PM
Modifying th350 valve body at home - Custom shift kit? Warrant Transmission - Rearend 5 11-24-2006 07:39 AM
1984 Corvette 700 Trans Wont Shift Up billybonesmusic Transmission - Rearend 3 06-06-2006 07:23 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
