Installing turbo 350 into 96 s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2009, 06:24 PM
Hello guys I am working on a 96 chevy s10 2 wheel drive and am going to put a turbo 350 into it when I get my engine done this spring. I already have a v8 in the truck but its on its last leg but the tranny in it now is a 700r4. What I am wanting to know is can I put in the turbo 350 with out having to fabricate anything on the transmission crossmember and tranny mount and anything else? I know the draiveshaft will have to be shortend. Thanks for any info.
Eric
Old 03-02-2009, 06:46 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You'll need a shorter drive shaft & move the cross member, you may need to drill some holes to mount it, the link below will give you tail housing measurements
Rich.
http://tciauto.com/Products/TechInfo/trans_dims.asp
Old 03-02-2009, 10:03 PM
SSedan64's Avatar
If you get a TH350 with the 9" tail, such as from a van or truck, they're the same length as the 700R4.
Old 03-03-2009, 07:26 PM
Hello thanks for the info that would be a lot of help. I do believe my turbo is a 6 inch tail shaft but I can buy a longer one if need be.
Eric
Need 350 SBC to 350 Turbo Torque Specs MikeD Transmission - Rearend 2 10-20-2013 10:26 AM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 08:48 AM
turbo 350 Tissue Engine 3 04-09-2004 08:05 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 09:25 PM
Installing New Shifter in Turbo 350 horvath Transmission - Rearend 4 02-18-2003 10:04 AM
