-   -   ???INSTANTLY HOT Manifolds??? (http://www.hotrodders.com/forum/instantly-hot-manifolds-52278.html)
Dizturbed One 11-19-2004 03:21 PM
The situation is explained in the second post of this thread http://www.hotrodders.com/t52273.html
Just thought I'd make a new topic to catch attention to the real subject in case someone has had this same peculiar problem.
4 Jaw Chuck 11-19-2004 05:12 PM
That will happen when you pass hot gases through a cast iron pipe.
You need to do some rebuilding of your carb from the sounds of your posts. Have you done a compression test? How about a leak test of the cooling system?
coldknock 11-19-2004 09:41 PM
Everything's groovy unless the manifolds are glowing red. If that's the case then check the timing, it's retarded.
Larry
mitmaks 11-19-2004 10:26 PM
not running lean?
