???INSTANTLY HOT Manifolds??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2004, 03:21 PM
Dizturbed One's Avatar
The situation is explained in the second post of this thread http://www.hotrodders.com/t52273.html
Just thought I'd make a new topic to catch attention to the real subject in case someone has had this same peculiar problem.
Old 11-19-2004, 05:12 PM
4 Jaw Chuck's Avatar
That will happen when you pass hot gases through a cast iron pipe.
You need to do some rebuilding of your carb from the sounds of your posts. Have you done a compression test? How about a leak test of the cooling system?
— Han Solo
Old 11-19-2004, 09:41 PM
coldknock's Avatar
Everything's groovy unless the manifolds are glowing red. If that's the case then check the timing, it's retarded.
Larry
Old 11-19-2004, 10:26 PM
mitmaks's Avatar
Last journal entry: Grille
not running lean?
