Instrument gauge wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2011, 03:29 PM
I'm wiring all new gauges in the instrument panel I made. It looks like it could turn into a rats nest real easy. 6 gauge lights plus all the rest. I would like to make a harness that could be disconnected easily. Any suggestion would be greatly appreciated.
Name:	Guage Cluster (2).jpg
ID:	53166   Click image for larger version
Name:	Instrument  cluster backside.JPG
Old 03-01-2011, 05:01 PM
EOD Guy's Avatar
I use these with great success
http://cgi.ebay.com/ebaymotors/PURPL...Q5fCarQ5fParts
Old 03-01-2011, 06:43 PM
LATECH's Avatar
Last journal entry: New Gas Tank
That looks pretty good EOD guy.I would agree that connector would serve this purpose very well.
Old 03-01-2011, 06:58 PM
The connectors mentioned by EOD Guy would help out a lot. I used a "Molex" connector kit from Newark Electronics for my build. The point is, the detachable connectors make things a lot easier. As far as the wires, there's no need for it to be a "Rat's Nest". Make a list of the wires you'll need (function, size, color, destination), and build a harness. Use plastic Ty-raps to keep the wires where you want them. Label the wires as to where they go, and keep things neat and organized. Watch out for any sharp metal edges that could damage the insulation on the wires. Leave a little bit extra for the terminations, in case you mess up a terminal. Even if you need many wires, take one at a time, and take your time. It really isn't that difficult. Just take your time, don't be intimidated, and you can do it yourself.
Old 03-01-2011, 11:02 PM
I started out with the 6 light wires. I soldered two together from each set into one and then three into one. I'm not sure if I like it or not.
Old 03-02-2011, 03:40 AM
EOD Guy's Avatar
Looking at your 1st photo, I'd run a bus bar type setup, all the light wires run to a single point, terminate with ring terminals then screw them to the bus bar. Do the same for the grounds. Insulated two post bus bar from radio shack/ebay just a couple of bucks, then I'd epoxy the bus bar to the rear of your panel, looks like you have plenty of room and it would make the install tidy.
Old 03-02-2011, 05:24 AM
This type of bus bar might be useful, since you can use one side for power leads and one side for ground, and it would be easy to fit multiple ring terminals. It appears to be designed for marine installations, so you might have to look at a boating supply store.
http://www.boatersplus.com/sierra-ge...nal-black.html
Bruce
Old 03-02-2011, 07:30 AM
delawarebill's Avatar
dash wiring
how about using 4 pin trailer plugs? flip the plugs so u don't get mixed up if u remove it.. i use them under my bucket for a quick disconnect if it ever need to remove the body.. 8 yr and never had a problem.
Old 03-02-2011, 09:21 AM
Footstomper
Last journal entry: 40 ford/cadillac coupe
I hate wiring
I was and still, I use a 40 ford gauges and 40 senders. The temperture gauge decided to go stop at 1/4. Electrical wire attached with the electrical fan, it worked. I changed to a tractor temperture and I it works great, now I don't have the fan. Should I buy a temperture with a range so the fan runs when I needed. I bet someone has around 190 degree to 200 degree. It is a 500 cadillac, someone told me that cads like higher, maybe 210. My oil quit, so I bought a plastic hose with a tractor oil gauge. I am putting the 40 dials to look 40. Don't get me on the turn signals!
Old 03-02-2011, 04:45 PM
EOD Guy's Avatar
Here's what I use on many applications.
http://cgi.ebay.com/Barrier-Strip-Te...item4aa5f6ec58
Old 03-02-2011, 04:46 PM
EOD Guy's Avatar
Hate it when it won't just let you delete a reply
Old 03-02-2011, 06:36 PM
The barrier strips, and terminal strips are good ideas, but in my opinion, a little over kill.
You have made what I would call a "Y" connection, with all the wires from each individual gauge coming to a common wire. It will work, insulate the bare solder joint.
I would use more of a "daisy chain" type of hook up for the gauge illumination. I have found you can put two or three 18 Ga wires in to a butt splice crimp on connector. I also often push the metal crimp connector out of the plastic tube, crimp it, than solder it, and then put heat shrink over that for insulation.
Old 03-02-2011, 06:47 PM
EOD Guy's Avatar
Bus Bar connection along with the 12/18 pin connector make for a neat install that can be easily removed if needed and easily repaired should that need arise.
Old 03-03-2011, 12:55 AM
I bought this 12 point bar awhile back but it seemed overly large. I guess I'll have to label all the wires and put them into one of those spilt plastic sleeves and run them to a couple bus bars. I was hoping I could find a male/female plug for everything. Thanks for all the suggestions. Always appreciated.
Name:	12 pin bus bar.JPG
Old 03-03-2011, 03:50 AM
EOD Guy's Avatar
Post #10 has a link for a male and female plug
A question on Instrument wiring hot_rod_kid Electrical 4 03-05-2011 04:10 AM
Gauge Wiring alf1096 Electrical 2 06-16-2005 08:22 PM
Amp gauge wiring ChevPuba Introduce Yourself 0 11-05-2004 04:55 AM
gauge wiring 49olds Electrical 1 10-16-2004 08:18 AM
INSTRUMENT PANEL WIRING bluechev4x4 Electrical 0 12-28-2002 01:01 PM
