INSTRUMENT PANEL - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2001, 04:15 PM
Wink INSTRUMENT PANEL
I AM TRYING TO HOOK UP A RON FRANCES WHOLE CAR WIRING KIT TO A 1993 CAMARO INSTRUMENT PANEL AND AM HAVING TROUBLE FINDING THE CORRECT VOLTAGES TO HOOK UP TO THE VARIOUS GAGES. RON FRANCES ONLY GIVES A GERNERIC HOOK UP. CAN ANYONE HELP? THANKS, WHITEY[*]nullnull
Old 12-16-2001, 05:17 PM
New Member
Post
I have not installed the harness that you are using, but I would tend to think that they are all pretty much the same. All of your gauges ( excluding the alternator ) should receive 12 volt power sourced from the "Gauges" terminal on your fuse block. If you are wiring the gauge harness yourself, you would need to daisy chain from one power lead from one gauge to the next. This will in turn also take care of the amps needed for the gauges. The alternator has a lead that is tied into alternator depending on if you are running a 1 wire system or not. You should also daisy chain your ground from one gauge to the next and follow you ground all the way to the fuse box. Connect this to your grounding block and you should be in business.
Please let me know if this helps, or if I am missing your problem. If you continue to have problems, we can look at other problems / solutions.
Old 12-23-2001, 07:45 PM
Post
all gauges usually receive 12 volts.
