insulation - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2004, 07:37 PM
New Member
insulation
Hey everyone a few weeks ago i was reading here about insulating inside cabs of trucks. yesterday i found insulation at home depot that is for hot water heater. it appears to be the exact insulation i found on several supply site on the web. only thing is it is $19.99 for the same 48 X 72 roll that is sold for $40 on the web. I used it, took 3 rolls for most of cab, it has foil heat reflector on outside and material padding on inside 3/8 in. thick. Hope this will save some of you some money.
Old 01-01-2004, 09:06 PM
jdcoic's Avatar
The Chicken Car
Did it make a noticeable difference in both noise and heat reduction in the cab?
Old 01-01-2004, 09:13 PM
New Member
big difference in noise not sure on heat yet have not been out on road yet. i think it said it reflects heat up to 250.
Old 01-02-2004, 02:53 PM
Custom User Text:
Good for the cab. I would not put it in the doors. In my mind it could help cause rust. Just my 2cents.
Old 01-02-2004, 04:09 PM
Tazz
I have found foam sprayed on the surface inside of the doors and in the trunk, but it wasn't rusted anyplace the foam was?? My Pontiac need's that heat padding bad, it need carpeting and door panels and head liner and ........much more! I have been driving it and my feet got hot from the hot floor.
Tazz
Rat Rods Rule!
Old 01-06-2004, 03:25 PM
VonGooch's Avatar
Mazooma!
Re: insulation
KA-CHING!! Thanks for the idea! I will soon be installing Home Depot insulation!
The Goochman
