Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - intak in the way of the vac advance
Old 06-22-2012, 04:09 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
The Distributor can be installed in any position needed. Just make sure the Plug wires & Rotor are aligned correctly. Use a long Screwdriver to align the Oil Pump driveshaft.
Distributor install >> http://www.chevytech.info/3c1o1.html
