intak in the way of the vac advance - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2012, 12:23 AM
1996thunderchicken's Avatar
ALL AMERICAN MADE
ok trying to set the timing and cant get to the 10 to 12 mark due to the vac advance canister hitting the intake runner can any one help me please car is a nova, engine is a 350, intake is a summit stage 3 intake, dizzy is stock gm hei and the instructions said works with hei what am i missing here.
Old 06-22-2012, 01:42 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
setting timing
move each plug wire to the next socket on the dizzy going in a counter clockwise rotation. this will advance the timing. you may have to turn dizzy in a clock wise direction to retard timing a bit to get motor to start. then use light again.
Old 06-22-2012, 04:09 AM
SSedan64's Avatar
The Distributor can be installed in any position needed. Just make sure the Plug wires & Rotor are aligned correctly. Use a long Screwdriver to align the Oil Pump driveshaft.
Distributor install >> http://www.chevytech.info/3c1o1.html
Vac advance vac source JCurry Hotrodding Basics 14 05-13-2011 01:22 AM
msd vac advance with no vac 85 k5 mud truck Engine 2 06-01-2009 08:38 PM
vac advance big red 1 Engine 8 10-19-2006 04:08 PM
vac advance help. Super Chevy Engine 52 11-14-2004 08:09 PM
HEI/vac advance/mech advance dion Engine 4 10-21-2003 08:43 AM
