Intake bolt leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 05:12 PM
v8hed's Avatar
AK427
Intake bolt leaking
Think one of my intake bolts is leaking (water) with the engine running, as it's pooling around the head of the bolt. However, my thermostat housing (which is directly above the bolt in question) also has a slight leak, which I've recently cured, so I'm not 100% sure yet. However, if my intake bolt IS letting water past, would it be OK to take just that one bolt out, apply (more) thread sealer and torque it back down, or would I have to loosen all the bolts in the proper sequence, even though I'm only wanting to get at one bolt?
Thanks.
Old 09-01-2008, 08:07 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
If it were mine, I'd yank the bolt in question and re-seal.. Do the simple stuff first..
Old 09-01-2008, 09:28 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Just fix the leaking bolt. Removing one bolt, resealing and retorquing it won't hurt anything.
Old 09-02-2008, 07:53 AM
v8hed's Avatar
AK427
Thanks guys.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
intake vac leak derek32303 Engine 5 08-09-2007 12:48 AM
Custom intake tube info (Cavalier, but good info for all) TheVis Engine 11 02-09-2007 04:44 AM
Leaking oil from a cyclinder through bolt Buckeye Engine 12 01-09-2007 11:52 AM
351C intake manifold question....??? Steve-0321 Engine 3 04-25-2005 07:44 PM
