Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - intake bolts being stuborn
Old 10-09-2012, 02:42 PM
cdminter59 cdminter59 is offline
Look on the flange behind the alternator and post the numbers for the block. Pull the valve covers and get the casting numbers for the heads and post them too. There is also a casting number on the back of the engine where the transmission bolts to the block. Can be on the drivers or passenger side. Like was mention before you might have vortec heads which uses a different manifold.
