Intake bolts clamping - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-12-2013, 06:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by spinn View Post
How about if I went with studs? Then I could use doubled nuts to secure the hold.
If that is even how it releases the hold. My thinking is from heat expansion.
Gasket crush is the culprit. Studs are fine (if somewhat of an overkill), but simply using bolts that are retightened until the gaskets take a set is all that's really needed. But regardless if bolts or studs/nuts, retightening is the key.
Studs can be used on any intake, usually. They require the studs being threaded in after the intake is in place. Not something I recommend, just saying.
  #17 (permalink)
Old 04-12-2013, 10:49 AM
spinn's Avatar
t clamps? What a unusual suggestion. How would you fashion them to hold down the vortec intake?
So the loosening is from a event. The heat cycle expands it. Then the gasket is left squished.
At some point the intake bolts should stay snugged. Now if they didn't...that is my problem. It seems over time the bolts holding my vortec style baseplate still loosen after almost a year. Many heat cycles later, and after any retorquing already done.
There is no leak, just concern. I happen to put a wrench on it.
T bolts?
  #18 (permalink)
Old 04-12-2013, 10:57 AM
As stated Vortec intake with the 8 vertical intake bolts require 11 lb/ft as already stated. The torque sequence is 3 steps, 2 lb/ft, 9lb/ft then 11 lb/ft. This per the 2013 Chevrolet Performance Parts Catalogue page 207. This is for all Vortec heads:stock L31 350, Bowtie Small port(185cc) and Largeport(215cc), Fastburn 210cc heads.
peace
Hog
  #19 (permalink)
Old 04-12-2013, 11:34 AM
spinn's Avatar
Are you suggesting something?
Do you think the gasket was compressed incorrectly. Like it was 2lbs, 5, and 11lbs. This would cause a failure?
  #20 (permalink)
Old 04-12-2013, 12:54 PM
No not at all, I was just going through a Chev Performance catalog earlier and saw the specs.
11 lb/ft feels like no torque at all, if it werent for the spec. I would use a little more torque.
The Vortec 305/350 trucks engines are notorius for intake gasket failures. the bolts apply the claming force are not perpendicular to the sealing surface. Since Vortec heads are iron, most intakes are aluminum(L30/31 are aluminum) so with every heat up/cooldown, the differnce in expansion/contraction rates between the heads/manifold start to roll the gasket. Also when Dexcool is exposed to air, like what happens in an underserviced cooling system, it becomes corrosive, corrosive enough to etch the cast iron heads. All these factors combined cause failures in the gasket seal.
Originally GM heralded the encapsulated silicone Vortec gaskets as reusable. This was later found to be false. Gm has redesigned these gaskets at least once.
Stock encapsulated silicone Vortec intake gasket
Felpro Vortec problem solver intake gaskets $69.99 These gaskets have metal caging in them.
GMPP offers a paper Vortec gasket($41.00)
12497760
Gasket Kit, Vortec Design
• Designed for Vortec heads P/N 12529093, P/N 12558060,
P/N 12464298 and P/N 12497186 only
• Gasket thickness is 0.120" (1/8"), post size is 1.080" x 2.160"
with tapered wall
• Has both early style 6-bolt pattern and Vortec 4-bolt pattern
• Includes 2 gaskets
they appear to be the same as FelPro 1255 Vortec gaskets for $33.00
peace
Hog
  #21 (permalink)
Old 04-12-2013, 01:30 PM
The GMPP gaskets above 12497760 , are NOT paper, they are composite W/Coating.
here are the Felpro encapsulated silicone Vortec gaskets Fel Pro MS90131 $37.99
See how the Fel Pro MS98000T Problem Solver (with metal caging) appears to be much more robust?
peace
Hog
  #22 (permalink)
Old 04-12-2013, 02:28 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Yep "problem solver", too bad you need to pay for the entire kit when all that is really needed is the side gaskets, these are great with lock pins too, have had my intake off 3 or 4 times and reused the gaskets never any problem or leak, just re-do the front and back beads with RTV black each time.
like I said,,, I think the song goes,,,dont worry be happy.
  #23 (permalink)
Old 04-12-2013, 06:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
T bolts?
The poster is a spammer. What he suggested is not applicable to an intake- those clamps connect pipe together.
The fasteners loosen because the GASKETS GET CRUSHED. It really makes no difference if this is because of heat or whatever. If you retighten the intake after each heat cycle until they take a set, all's going to be fine. Neglect to do so and I can assure you, you're going to have problems.
Have used Fel Pro MS98000T gasket set (>$50!) w/good results. Mine came w/only one silicone valve cover gasket. Checked and that's how they came, then. Don't know about now. Do not over torque them.
intake bolts being stuborn JOHNSHENOUDA Hotrodding Basics 15 10-15-2012 07:57 AM
intake bolts not lining up sam_bo3 Engine 3 01-28-2012 02:21 AM
SBC intake bolts Cape Cod Bob Engine 3 05-27-2008 07:36 AM
305 intake bolts malibus~most~wanted Engine 7 03-31-2008 06:56 PM
What bolts for intake manifold sabino56 Engine 4 08-01-2006 07:45 PM
