Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intake + Carb for 305HO then to built 350 (74')
Old 02-25-2003, 04:50 AM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
I would if I was gonna go legal would be,emmissions headers and crossover,highflow cat,and large tube cat-back.Then use either an edelbrock or weind egr intake.Keep the A.I.R hooked up.
Run the Q-jet with the feed bac vapor can thing and electric distributor for inspection. Then for driving put the Holley on and the vac advance distributor and pull off the belt to the smog pump.Tuck the computer harness away till next inspection.
This way all you'd need for inspection would be to change carb,distributor and put a belt on.
