Intake gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 12:27 AM
Madmax305's Avatar
Intake gasket?
I am putting on a new set of vortec intake gaskets due to an intake vacuum leak. I know to use RTV on the china wall area, do I need to put RTV anywhere else on the head or gasket. I will be using this gasket.
Fel-Pro Q1255 - Fel-Pro Performance Intake Manifold Gasket Sets - Overview - SummitRacing.com
Old 08-23-2012, 05:19 AM
engineczar's Avatar
Out of habit I always run a thin bead around all four water jackets. I can't say I've ever had one leak but at this point you can't teach an old dog new tricks. I also put a dab on the threads of the bolts to keep the oil from wiking up them.
BSE Racing Engines
Old 08-23-2012, 06:02 AM
malc's Avatar
Born To Be Mild
X2
Too much and the gasket will "walk" as you tighten the bolts.
One time I overdid the RTV.
Old 08-23-2012, 07:17 AM
I put a very light coat of RTV on both sides around all water jackets. I also use gasket-cinch on the head side in between the intake ports and heat riser area to hold the gasket in place while torquing.
Old 08-23-2012, 08:36 AM
Last journal entry: my 88
dont use the gaskits on the front and back use the rtv it works better
Old 08-23-2012, 10:47 AM
boatbob2
F and R gaskets...
Hi,i take a small center punch,and put punch marks about every 1/4 inch,on the front and rear of SBC blocks,where the intake rubber gasket WOULD GO,but i dont use those gaskets,i put about 3/16 inch of RTV there..never had one leak...the punch marks hold the RTV good.
Old 08-23-2012, 12:16 PM
i can see how those punch marks would add to the grip of the rtv.
Old 08-23-2012, 02:19 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: Test Drive (finally)!
The Vortec gaskets are different than the old school SBC intake gaskets. I would avoid using any RTV or stuff on the water jacket or around the ports as this will probably cause a leak or crack the gasket. The instructions for your gasket clearly state, "Installation to be done with a bead of silicone at the manifold ends."
Old 08-23-2012, 03:13 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Do yourself a big favor and get the GM type of intake gasket for the vortec heads. They have the pins for locating the intake gaskets and are reuseable. Use RTV black as mentioned on the rails.
This kit has more parts than you need but rest assured a little extra $$$ is worth, I have removed my vortec intake 3 times and reused them without a problem along with the RTV thick bead on the rails
Fel-Pro QMS98000T - Fel-Pro Intake Manifold Gaskets - Overview - SummitRacing.com
No other beads of RTV are needed around water ports.
These work
2 more of my cents
Old 08-24-2012, 04:44 PM
Madmax305's Avatar
I changed the intake gasket with the Fel-pro 1255, Used a little RTV around the water jackets. Problem solved. Thanks for all the replies.
intake gasket studebaker46 Engine 5 02-26-2006 07:26 PM
possible intake gasket problem silverado 1 Engine 3 09-20-2004 06:05 PM
Intake gasket Sub_Urban_454 Engine 5 11-04-2003 06:38 AM
Intake Gasket II Sub_Urban_454 Engine 29 11-03-2003 11:17 PM
Intake gasket pcesak Engine 5 06-19-2003 09:45 PM
