intake/head/exhaust question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 10:26 PM
what is the compatibility between intake manifolds and heads...
how specific is the match.
for instance a 307 block with a 350 intake.
or 327 with 350 intake.
i notice the intake manifold chambers are a different pattern then the exterior port chamber pattern on the head, where the headers(exhaust)connect...
any help?
Old 03-26-2012, 10:58 PM
DoubleVision's Avatar
The only difference in factory stock intake manifolds was the mounting flange for 2 or 4 barrels and the size of the intake runners. The small cubic inch engines got 2 barrel carbs with small runner 2 barrel intakes. THe small runners created high velocity to give these small engines better low end torque and throttle response to help get the vehicle moving out of the hole.
The 4 barrel intakes had slightly larger runners.
There were several exhaust manifold types used by chevy, the rams horns which are center exit, the log style which is one long manifold with a rear dump and the sweep back manifold which also has rear exits. THe rams horn style used in the 60's and early 70's flowed the best of the three.
Cylinder Head and Intake Manifold question cobrajet Engine 10 05-17-2011 01:17 PM
1.7 exhaust and 1.8 intake on bbc garbely1 Engine 0 03-04-2010 11:36 AM
Bowtie Head/Intake Question f401trd Engine 4 02-16-2010 04:34 PM
Changing exhaust to intake and intake to exhaust? BillyJoe Engine 3 03-28-2006 06:29 AM
ford head i.d. and intake question tonylsg Engine 8 06-06-2003 04:09 AM
