Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - intake hunting
Thread: intake hunting
Old 12-12-2012, 06:11 PM
hcompton hcompton is offline
Old & Furious
Originally Posted by j-stylez View Post
Thanks for the tips guy! I'll certainly check out those links. I like the idea of trying to make my own too, but my stove ain't big enough !LOL
Go to a place that builds and installs roll cages and have them make you some tight bend and weld up out of roll cage style pipe this thick wall pipe is easy to weld and will not crack as easy.
Or You can use a drill press to make a plate manifold out of 1/4 inch steel stock. If the intake port are close together you may be able to use side draft webbers and the plate with some short pipes and mounting plates to hold down the carbs if you understand me.
