-   -   intake hunting (http://www.hotrodders.com/forum/intake-hunting-227076.html)
j-stylez 12-11-2012 04:33 PM
intake hunting
G-day all, Just wondering if any of you know if there was ever any kind of a 4 bbl or multi-carb intake made for a Chrysler straight 8?:D
thanks
SSedan64 12-11-2012 08:21 PM
If there had been it probably would have been listed here > http://www.exeterautosupply.com/Docs...%20catalog.pdf but, I only see Chrysler/Dodge/Plym 6cyl.
66GMC 12-11-2012 09:15 PM
I just checked at Clifford Research (the inline 6 performance experts) but didn't see any Chrysler Flathead 8 stuff.
I also thought of Inliners International devoted to all Inline powered vehicles ... but I didn't dig to deeply. I would imagine that signing up on their BB might get you some sources?
cobalt327 12-12-2012 01:42 AM
thanks
Click on the image to link to the p15d24 board, you're bound to get info on the intake there. HAMB would be another good place to ask. Good luck.
http://up.picr.de/8141644wen.jpg
More:
Help needed-Intake manifold ID 30's-40's
timothale 12-12-2012 06:35 AM
you can do it.
Years ago there used to be kits you could buy to add a couple more carbs to your stock 2 barrel manifold by using a hole saw and welding them on, In the mid 50's I split my 6 cyl exhaust manifold, make new steel pieces, cut the stock manifold, then heated up the manifold in the wood burning stove with a hot fire when the folks were gone, I had the Arc welder cord thru their bedroom window, pluged into the elect. stove outlet in the kitchen, welded it all together with E 60 11 rod then ran it back inside the house and put it back into the firebox and let the fire slowly die down and slooow cool the manifold. Ufab intakes sells kits for V8's and some inliners but I haven't seen any for your engine, but you might be able to buy some pieces. My brother built a 6 carb manifold for his hemi in his dry lakes 36 ford. I have been looking at a 6 carb kit for My buick nailhead.
66GMC 12-12-2012 06:54 AM
Thanks for the link, Cobalt.
The good news is that Thickstun DID make a dual-carb intake for the Chrysler straight 8 (according to this article)
The bad news is that Vic Edelbrock started out at Thickstun ... so that tells you how long ago that manifold was produced! :D
Who knows, though ... you may end up finding one on e-bay.
j-stylez 12-12-2012 05:13 PM
Thanks for the tips guy! I'll certainly check out those links. I like the idea of trying to make my own too, but my stove ain't big enough !LOL
timothale 12-12-2012 06:02 PM
BBQ a whole Cow.
You can get some bricks make a fire pit and use charcoal, My older brother told me about a guy that he knew heated a 4 cyl block with charcoal, added ribs to the bottom end. I don't know how Nickel arc rod would work. It is expensive. If you have a gasket to use for a pattern you could make or order the plate from Ufab, some tubing and carb plates . I made a spider leg intake for my corvair powered/dunebuggy. I machined the intake portion of the combo-head-intake . added more carb flanges, then built the manifold like a set of headers . 3 pipes coming up from each side to the carb box. It would pull the wheels up in second gear.
