intake hunting - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2012, 05:33 PM
Last journal entry: pickin' away
intake hunting
G-day all, Just wondering if any of you know if there was ever any kind of a 4 bbl or multi-carb intake made for a Chrysler straight 8?
thanks
Old 12-11-2012, 09:21 PM
SSedan64's Avatar
If there had been it probably would have been listed here > http://www.exeterautosupply.com/Docs...%20catalog.pdf but, I only see Chrysler/Dodge/Plym 6cyl.
Old 12-11-2012, 10:15 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I just checked at Clifford Research (the inline 6 performance experts) but didn't see any Chrysler Flathead 8 stuff.
I also thought of Inliners International devoted to all Inline powered vehicles ... but I didn't dig to deeply. I would imagine that signing up on their BB might get you some sources?
Old 12-12-2012, 02:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
thanks
Click on the image to link to the p15d24 board, you're bound to get info on the intake there. HAMB would be another good place to ask. Good luck.
More:
Help needed-Intake manifold ID 30's-40's
Old 12-12-2012, 07:35 AM
Wiki Edits: 27
you can do it.
Years ago there used to be kits you could buy to add a couple more carbs to your stock 2 barrel manifold by using a hole saw and welding them on, In the mid 50's I split my 6 cyl exhaust manifold, make new steel pieces, cut the stock manifold, then heated up the manifold in the wood burning stove with a hot fire when the folks were gone, I had the Arc welder cord thru their bedroom window, pluged into the elect. stove outlet in the kitchen, welded it all together with E 60 11 rod then ran it back inside the house and put it back into the firebox and let the fire slowly die down and slooow cool the manifold. Ufab intakes sells kits for V8's and some inliners but I haven't seen any for your engine, but you might be able to buy some pieces. My brother built a 6 carb manifold for his hemi in his dry lakes 36 ford. I have been looking at a 6 carb kit for My buick nailhead.
Old 12-12-2012, 07:54 AM
66GMC's Avatar
Thanks for the link, Cobalt.
The good news is that Thickstun DID make a dual-carb intake for the Chrysler straight 8 (according to this article)
The bad news is that Vic Edelbrock started out at Thickstun ... so that tells you how long ago that manifold was produced!
Who knows, though ... you may end up finding one on e-bay.
Old 12-12-2012, 06:13 PM
Thanks for the tips guy! I'll certainly check out those links. I like the idea of trying to make my own too, but my stove ain't big enough !LOL
Old 12-12-2012, 06:42 PM
hcompton's Avatar
Old & Furious
Call edelbrock and ask if they can still cast you one. If they have sold it in the past they will usally build you one up. Since they have been making parts for years its a good chance they made on at somepoint and may have them on the shelf. You will need to call, internet request will probably result in random information as you never know who will answer. A great etch or some arse clown in the customer service department.
Old 12-12-2012, 07:02 PM
Wiki Edits: 27
BBQ a whole Cow.
You can get some bricks make a fire pit and use charcoal, My older brother told me about a guy that he knew heated a 4 cyl block with charcoal, added ribs to the bottom end. I don't know how Nickel arc rod would work. It is expensive. If you have a gasket to use for a pattern you could make or order the plate from Ufab, some tubing and carb plates . I made a spider leg intake for my corvair powered/dunebuggy. I machined the intake portion of the combo-head-intake . added more carb flanges, then built the manifold like a set of headers . 3 pipes coming up from each side to the carb box. It would pull the wheels up in second gear.
Old 12-12-2012, 07:11 PM
hcompton's Avatar
Old & Furious
Go to a place that builds and installs roll cages and have them make you some tight bend and weld up out of roll cage style pipe this thick wall pipe is easy to weld and will not crack as easy.
Or You can use a drill press to make a plate manifold out of 1/4 inch steel stock. If the intake port are close together you may be able to use side draft webbers and the plate with some short pipes and mounting plates to hold down the carbs if you understand me.
hunting or non hunting gear ratio blownblazer Transmission - Rearend 12 02-06-2015 04:17 PM
May have to give up Hunting? HotRodMan Hotrodders' Lounge 10 09-03-2009 06:46 PM
a-hunting i will go davetc Transmission - Rearend 1 08-26-2004 06:22 AM
Hunting Checy_Guy Hotrodders' Lounge 20 02-16-2004 11:07 AM
went Elk hunting bowtienut Hotrodders' Lounge 17 09-25-2003 01:15 AM
