The gap you see at the front and rear between the intake and the block is common when using AFR heads.
AFR sells metal spacers (I believe in 1/4" and 5/16" thick) to take up some of the gap. I also had this occur when installing an Edelbrock Air Gap intake on AFR heads. What I did was use two of the cork gaskets on each end with clear silicone liberally applied as well. Let the silicone set up for about ten minutes before installing the intake. Set the intake straight down onto the engine and try not to slide it around any. Do not use the rubber gaskets as they will slide out of place easily when tightening down the intake. If the gap is not too great (less than 1/8") I use the silicone only with no other gasket on the ends. I also suggest applying some (just a light coating) silicone around the water jacket sections of the intake manifold gaskets. NOTE: Here is a link to the AFR site concerning the intake to block spacers. Scroll down to near the bottom of the page to see the available thickness and part numbers. AFR intake to block spacers You might wish to go to the installation instruction section on the AFR site and print out the info. It is very helpful when using their heads. Last edited by Frisco; 09-18-2008 at 05:51 PM. Reason: Added link to spacers |
Thanks for the help Frisco and Carsavy, I just put a very thin coating of the Aviation Form a Gasket around the water jackets and I used the red High temp sealer on the ends just cause it's good to 650F instead of 500F. Sure it probably doesn't really need it but hotter is better. The gap only ended up being about 1/16" once I snugged it down to check it so I think it's good the way it is.
Thanks again, Sean |
The heat factor is not important in this application. Red high temp silicones are designed for use on exhaust systems, not for oil, and water applications.
I wish you luck. |
I had never heard of, or seen any advertisements for this product. After checking out it property's online, I will definitely give it a try. I have had great success with their "ultra" series sealants for years, and like the 'you can put it right to use' claims on their website. Stephen |
| Removing intake on SBC... help! | v8hed | Engine | 14 | 06-06-2008 04:35 PM |
| High oil consumption after intake and valve cover change | junkyardjeff | Engine | 5 | 05-17-2008 10:40 PM |
| Need Hood Clearance - Intake ? | 68chevelle_ss | Engine | 6 | 06-30-2005 08:10 PM |
| Intake port matching AFR heads | 406chevelle | Engine | 2 | 01-16-2004 05:26 PM |
| port matching the intake. | Jmark | Engine | 9 | 12-08-2003 10:13 AM |
