intake leak HELLLLLLP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2008, 05:15 PM
Hey guys, the car is a mother mopar special 73 roadrunner with a 440 big block. OK, I appreciate the insights so far on the oil under my intake in the valley..I went top the autostore and bought another breather cap and put it on the cover that had a regular cap...I now have two breathers. I do see the nipple under the carb for a pvc hose but there isnt a spot on the mopar covers to put a pvc!? Anyways, I cleaned up the oil under the intake and now im gonna get it hot and see if If I leak....if so I guess i will take off the manifold,again and put a brand new valley pan and permatex the bolts like that hotrodder said to do. thanks. If this doesnt work I think I will sell the car and buy a skate board. HMM..85.00 to fill up vs 5mph...hmmmm
Old 06-30-2008, 06:36 PM
SSedan64's Avatar
You should be able to get a rubber grommet that reduces the size of the breather hole in the valve cover to fit the PCV valve.
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
Dart intake? Brodix or Dart Heads? Slowass72 Engine 3 01-20-2004 04:52 PM
Intake port matching AFR heads 406chevelle Engine 2 01-16-2004 05:26 PM
Intake Chevy Guy Engine 2 04-27-2003 08:06 PM
