Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intake Leak Into Lifter Valley???
Old 10-12-2012, 09:14 AM
1965tripleblack 1965tripleblack is offline
Originally Posted by engineczar View Post
When you have the intake off is there oil in those three ports? Are you sure it's the intake and not valve guides or valve seals?
There's oil in most of the ports, and the valves have oily crud on them. Not sure which, but "most of" best describes the situation. The heads are brand new aluminum and the seals are brand new, gray/white in color with full metal jacket to hold the boss. I installed them, and I'm told that they are "the good ones for street/strip use". Not Teflon, but Viton?
