Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intake Leak Into Lifter Valley???
Old 10-13-2012, 04:56 PM
1965tripleblack 1965tripleblack is offline
Originally Posted by thinwhiteduke View Post
Does your rocker cover have a baffle installed?
I run those crappy thin pressed moroso covers and I ripped a breather baffle out of a stock sbc steel pressed rocker cover and rivited it into the moroso cover for mine, mine doesn't suck oil.
You could also try putting an inline fuel filter in the PCV hose, that should trap it. Dont know how long before it would become saturated though. Haven't tried it but I heard that Grumpy Jenkins had.
Duke
The taps are not in the valve covers, which are cast aluminum Corvette covers. Was thinking about sticking a separator like used in air compressors into the line, so I could watch it and drain when needed. It would fill up in about 100 miles, based on my consumption, so not practical.
Want to figure a better system, if possible. First need to understand why it's happening, and if it's normal, or not.
