Intake Leak Into Lifter Valley??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-13-2012, 11:56 PM
thinwhiteduke's Avatar
Living In The Past
Originally Posted by 1965tripleblack View Post
The taps are not in the valve covers, which are cast aluminum Corvette covers. Was thinking about sticking a separator like used in air compressors into the line, so I could watch it and drain when needed. It would fill up in about 100 miles, based on my consumption, so not practical.
Want to figure a better system, if possible. First need to understand why it's happening, and if it's normal, or not.
Where are the taps?
  #17 (permalink)
Old 10-14-2012, 12:00 AM
Living In The Past
Where are the taps? Is there some form of baffle incorporated?
Duke
  #18 (permalink)
Old 10-14-2012, 04:57 AM
Duke
See post #13. The oil fill tube goes into the timing chain area at front of block. There is no baffle.
  #19 (permalink)
Old 10-14-2012, 11:24 AM
RWENUTS's Avatar
Let's see!
You got an intake that won't seal cause the block and possibly heads have been shaved but the intake hasn't been cut to fit the changed angles.
You got a road draft tube hooked to the aircleaner that's putting oil into the cleaner.
You got a pcv on the oil fill tube but it's not connected right now.
You got high crankcase pressure pushing oil into your cleaner and into the intake ports cause of the mismatched sealing surface.
It's a no brainer!
Cut the intake to fit the angles and get your pcv set up right.
Burn us off a pic of your set up!!
  #20 (permalink)
Old 10-14-2012, 01:07 PM
If you want to use the PCV it might be time for some new valve covers. I know the Corvette covers are nice, but these have GM type oil baffles and cast in oil drippers like the 1970 LT1 aluminum covers. Don't let the picture fool you, they don't have the oil fill cap, I drilled it myself, but no matter since you have the oil tube on the intake. Maybe something to think about?
141108 - Die Cast Aluminum Valve Cover - SBC, Polished with Recessed Emblems, Tall w/Baffle
ssmonty
Name:	DSC02746 (Small).JPG
ID:	68407   Click image for larger version
Name:	DSC02747 (Small).JPG
Lifter valley standpipes? sexypizzaman Engine 14 09-17-2014 04:13 PM
relubing cam from lifter valley candrive55 Engine 7 07-09-2010 07:17 AM
Lifter valley Girdle? 84TA406 Engine 2 09-29-2009 05:53 PM
Cracks in lifter valley Spankdaddy Engine 10 10-16-2008 12:45 PM
Lifter Valley Canadian Charlie Engine 7 09-10-2005 02:00 PM
