Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - intake manifold
Thread: intake manifold
Old 06-17-2012, 07:10 PM
LATECH's Avatar
LATECH LATECH is offline
Spraying is good for an external leak, BUT will not reveal a leak from the crankcase side.
To check that , you need to pull the pcv from its fitting and block the hole with a plug. Then on the vent side plug in a vacuum gauge. It should build a small amount of pressure due to blow by , even on a healthy engine, if the gauge goes into a vacuum, that would indicate an internal leak from the crankcase side.
Fact is stranger than Fiction
