intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 05:08 PM
intake manifold
Whats the best way to check for intake manifold leaks? Im using a performer aluminum intake with an edelbrock carb and im not sure how to check for leaks. The car will not stay running when put in gear but runs fine with no load. PS its a 1964-68 chevy 283 installed in an 83 chevy caprice for my son.
Last edited by hunter0766; 06-17-2012 at 05:10 PM. Reason: to list what engine it is
Old 06-17-2012, 07:01 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Just carburetor cleaner and spray around the edge on the manifold and the base of the carburetor and if the idle changes then you know there is vacuum leak.
Old 06-17-2012, 07:10 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Spraying is good for an external leak, BUT will not reveal a leak from the crankcase side.
To check that , you need to pull the pcv from its fitting and block the hole with a plug. Then on the vent side plug in a vacuum gauge. It should build a small amount of pressure due to blow by , even on a healthy engine, if the gauge goes into a vacuum, that would indicate an internal leak from the crankcase side.
Fact is stranger than Fiction
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 07:49 PM
intake manifold gilliganspl Engine 3 07-28-2004 01:53 PM
Intake Manifold rbfpezcore Engine 2 07-23-2004 04:14 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
Intake Manifold fsiramps Engine 2 02-13-2003 05:26 AM
