Intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2013, 12:22 PM
Intake manifold
Hello everyone, i have a 1982 ford 302 motor and i would like to put an aftermarket intake on it. The stock manifold has rear coolant crossover ports.If i use a manifold without this provision will overheating be an issue?
Thanks .Joe
Old 10-25-2013, 03:18 PM
Thanks .Joe
No problem with overheat, this was done to balance up coolant temps between left and right sides at the rear for emission purposes.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
burnt clutch (10-25-2013)
Old 10-26-2013, 02:10 AM
JeffB's Avatar
If you check out most Ford SBF used aluminum intakes most will have corrosion in the water ports and even where they are blocked off they corrode.By having all ports open and flowing you eliminate that restriction and it promotes more even cylinder temperatures.I chose this intake almost four years ago: FORD 289 302 5.0L Polished Aluminum Intake Manifold - KMJ Performance It has open water ports front and rear so I was able to relocate the front heater hose port to the rear since I needed the space with the HEI and A/C.The fit was perfect and it just wipes clean with a soft towel,the low end and mid-range power is very strong and better than the Edelbrock that I had on before.
Name:	'54 Engine & AC 007 (Medium).jpg
Intake manifold JG700 Engine 9 07-06-2007 08:16 AM
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 07:49 PM
Which Intake Manifold? joe brienza Engine 4 08-18-2004 09:03 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
Intake Manifold ID SAATR Engine 5 12-10-2003 04:56 PM
