Intake Manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2004, 02:51 PM
rbfpezcore's Avatar
Not fast, but loud as hell
Intake Manifold
I am new to the whole restoration process and I had a question about the intake manifold. I removed all the bolts and the distributor does not run through the manifold, it is a ford 302. I am having trouble removing the manifold. Bolts are off and i took valve covers off so I don't bang them up as well. Should I just pry it off and use brute force or is there some way of finesse i should use. Any advice?
Old 07-23-2004, 03:15 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
finesse it off with a bigass prybar.
Old 07-23-2004, 04:14 PM
Almost an old guy...
I'm with crazy larry, sears makes a fine one with a plastic handle and a screwdriver tip that is about 16" long, one of the best prybars I own
