intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2003, 05:22 AM
Post intake manifold
Changed my motor, the new motor has plugs in the block where my old temp sensor plugged in. I see a plug next to the thermostat on the intake, I was wondering if I could run my temp from there. I guess I'll be monitoring the water temp then. Should I still monitor the temp by placing a sensor in the side of the block?
Where should my water temp read?
Old 02-21-2003, 08:17 AM
MI2600's Avatar
Member# 3287
Post
The older SBCs had the temp senders in the intake. Probably around '68 or so, they put a hole in the heads for the sender. I've never seen a place in the block itself. You can use either place. Just make sure the intake sender does not interfere with the thermostat housing or radiator hose.
