"Intake manifold bolt pattern with center bolts canted @ 72 angle" - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 05:29 PM
Im working on my neighbor's truck and im trying to find an aftermarket intake, but Im having a little trouble. It's a 1988 Chevy 1500. It has the L05 motor, and evidently it has the center bolts on a 72* angle. If I had the right idea on what to search for that would be great. Thanks for the help!
Old 04-05-2013, 05:46 PM
Most post-87 non-Vortec manifolds (which you are trying to find) were for TBI, and you want to use a carburetor. One option is to use bolt adapters that allow you to put a 55-86 manifold on a newer engine. However, I have no experience with how well they work.
I looked through the Summit racing online catalog and they have at least two sets of manifold bolt adapters that might work. I would also suggest calling them to find out if they have a manifold that will directly bolt on without an adapter.
Bruce
The Following User Says Thank You to 75gmck25 For This Useful Post:
91CamaroDude (04-05-2013)
Old 04-05-2013, 05:54 PM
Well, now after some search on what I should be looking for, I may have come across something?
Edelbrock 2104 Edelbrock Performer Intake Manifolds for Chevy
It says its "SB-Chevy 262-400ci 1955-86 w/1987-95 Cast Iron Cylinder Heads"
Sounds like what Im looking for?
Old 04-05-2013, 07:14 PM
Cape Cod Bob's Avatar
Or, you can ream out the holes on an older intake needed to allow the bolts to clear.
Old 04-07-2013, 08:40 AM
if you beat my boat, well race
i have used this intake before, on a 91 chevy 350 out of a caprice.
i bought a conversion intake for this car (37 chevy)
the intake is the same as a pre 85 small block. with aluminum "lugs" that let you use the angled bolts.
worked fine no problems. this is very common in the hotrodding world. good luck
Old 04-07-2013, 11:43 AM
bondo's Avatar
Ayuh,... That's the ticket, Right there,...
That manifold fits the in-between intake bolt pattern,....
Before '87, was the original SBC intake bolt pattern, 'n after '95 is the Vortec intake bolt pattern....
Old 04-08-2013, 08:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That intake will work. There are others, just be sure they specify that the intake fits the '87-up non-Vortec iron heads. The Corvette aluminum heads of that era used the older style intake, that's why cast iron is specified.
A recent thread w/similar info: 350 k code engine
Good luck.
Old 04-08-2013, 09:21 AM
Faith - Respect - Trust
LOL...from now on and forever, when I see a post starting with "Ayuh" I will know who it is. Good to see you posting.
Ray
Edelbrock Intake Manifold "EnduraShine" Finish 64Joker Engine 0 03-22-2011 07:29 PM
3998993 sbc heads - Canted Center Bolts Ironman Engine 3 11-22-2008 10:01 PM
Need help with Canted Center bolt SBC ID Ironman Hotrodding Basics 0 11-21-2008 08:50 PM
bolt pattern 5 on: 5 1/2", 4 3/4", 4 1/2" bolt circles which is best? 37ford4dr Suspension - Brakes - Steering 21 01-05-2006 03:01 PM
SBC "Rams Horn" Manifold Bolts- Size?? acr Engine 4 03-30-2005 08:49 PM
