Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - intake manifold bolts
Old 08-07-2010, 03:11 PM
oldbogie oldbogie is offline
Originally Posted by 49dream
i bought a Eldelbrock durashine intake manifold
I need some bolts that are chromed or at least match the manifold shine
I was on Eldelbrock web site and they don't offer any.
Would polish stainless work? or any suggesting where to get them
Thank you
Mark
Yes, but it is a good idea to use a hardened washer between the aluminum intake and the bolt head as this greatly reduces damage to the intake as the bolts are torqued up. Be sure to use a sealant on the bolt threads to stop any oil or coolant weepage. Plumber's Teflon paste type pipe thread sealant works well, it provides the right amount of lube in the threads so the torque readings match the booked values and it provides an excellent oil and coolant tight seal.
Bogie
