Hi Ozzie, sounds like your building a good all-around have fun vehicle. I also built a 350 Vortec to use in my 51 Willys. In answer to your questions, I used an Edlebrock performer manifold on mine and it seems to be working out OK. As I'm sure you know, Edelbrock makes the Performer, Performer RPM, and the Air-Gap Performer RPM for the Vortec engine. I'm reasonably sure that the Performer is the shortest of the three and would fit under the hood of your TransAm. The old saying is anything will fit under the hood......the question is if the hood will close with the manifold you choose. If memory serves me right, I believe there are height specs in the Edelbrock catalog. Might want to investigate there. As for a carb, your right to err on the smaller side since most of your RPM will probably be under 4000 RPM. Edelbrock makes two carbs which would suit you. Either the Performer Series or the Thunder Series. Both are based on the old AFB theory, but have been revamped by Edelbrock. I'm guessing your in 20's and don't remember too many cars of the 50's. The AFB (Aluminum Four Barrel) was used on Chryslers and some others back then and was a good carb. It has the advantage of being able to change the jets without flooding the manifold with raw gasoline. But I'm sure their are as many pro's and con's to the Edelbrock carbs as there are to Holley. The Performer is available in a 600 and 750 CFM models and the Thunder series is available in 650 CFM. Anything more than that would be a waste of money on the street. EFI is nice, but like you say, pricey. If you want to keep it emissions legal, than the basic rule is: if it came from the factory with it on, it needs to be on. That includes air pumps, catalytic converters, all vacuum accessories that effect emissions, etc. Most of the states, especially CALIF is really sticky about modifying and "altering" emissions. One way of getting around this is having the vehicle registered in your home state, if your home state isn't one of the sticky emissions states. As long as your on active duty in the military, most states have an agreement with other states that an active duty military member does not have to have an instate registration. Check with whatever state your being assigned to. Lastly, unless the manifold is setup for EGR you wouldn't be able to put one on. Like I said earlier, if came from the factory with one, it has to have one, same place, same function. A correctly functioning EGR valve doesn't alter performance enough for you to notice in the seat of your pants anyway. Good luck Ozzie. We appreciate the great job you and your fellow military men and women are doing to preserve freedom all over the world. Be safe!
On the other hand, if you're going to keep your registration from your home state while you travel with the military, just follow the emissions laws of your state. Its not legal to do in most states since you have to register a car X number of days after you move there, but many people get away with it. This also affects my reply to your exhaust thread; if you're planning on registering the car potentially in any of the 50 states, make sure you headers, exhaust, and all speed parts are either stock replacement (like the heads and catalytic converters) or carry a CARB EO number (like the intake, ignition, etc.). Cams will either be stock replacement (which are legal) or performance (which are not legal). Since the cam is internal, they can't fail you just for having a non-exempt cam in your engine, but it doesn't take long for the tailpipe sniffer to fail you with a hot cam. Quote:
There are three levels of smog legality; 1) stock replacement part. This covers things like a Comp Cam that is a copy of a factory GM cam, a Fram air filter designed for directly replace your original, or a Holley fuel pump that delivers the stock flow and pressure. These are parts that are designed by the aftermarket for stock performance and emissions. 2) Smog exempt. These carry the CARB EO number. They are performance parts that have been tested and shown to not increase emissions, so they are legal. That is not to imply that you will always pass emissions with those parts since you can still fail the sniffer test, but you won't fail a visual by having those parts. 3) Off road, or for non-pollution controlled vehicles. These are the performance parts like the tunnel ram intakes, huge race heads, or monster cams. The bottom line is the Federal Government doesn't even allow you to put ANY aftermarket performance part on your car. It has to stay in stock configuration and the only parts you are allowed to put on it are the stock replacements from the first category above, but the only Federal Agencies who could cite you for a violation are the FBI or a Federal Marshall, chances are you won't get busted for a Flowmaster muffler by Special Agent Fox Mulder. |
I just thought of something else... if you go EFI, you could do one of the Edelbrock smog legal EFI conversions. Then you could eliminate the problem of tuning idle on that electronic Qjet.
Another option is to use a GM factory EFI setup from a year later than your car. California allows engine swaps as long as the engine was available in the car (and since a 350 is externally identical to a 305, no one will know) and its from the same or newer year. You could swap a later engine management system, like off of another GM passenger car from your year or later; TBI, Vortec, etc. They won't check the year of the block, so you can just tell them that the engine is a 305 from a 92 Caprice. If you want to register it in CA, make sure ALL of the emissions equipment; EGR, evap canister, smog pump, everything gets transplanted from the donor car. Then you have it taken to a referee station to be certified as a legal swap. From then on, the smog test goes like this; you visit the smog station and they look at the TBI and **** their head sideways with confusion. You point out the recertification sticker on the door jamb from the referee station. Then they open up their smog manual to check for the laws about engine swaps since they've probably never seen a referee plaque before. Its a headache, but do-able. |
GM Performance Parts has a dual plane intake for the Vortec heads that is nearly identical to the Performer and it is available with EGR, both manifolds will accept either a spreadbore or squarebore carb. Be advised the GMPP piece is considerably more expensive. Edelbrock used to make a carb spacer for squarebore carbs with the pad for EGR so you could retrofit EGR to an older intake, they may still have it available and if they might have one for the spreadbore.
There are currently 2 intake bases I am aware of for installing TPI on Vortec heads, one from Edelbrock and the other from Scoggins-Dickey and both are right at the $400 mark and you would still need the rest of the injection system. The only TBI setup I know of is the factory piece. |
Jet performance makes high performance remanufactured Q-jets that you will be able to use and hook up all of your factory emissions equipment. I think Edelbrock does the same. Jegs or Summit should have these carbs.
Well, I just got back to the US from Germany and I'm wanting to spend some of my hard earned money to make this thing fast...too bad we don't have any autobahns here...these Wide open and FLAT roads in New Mexico are completely wasted on 60mph speed limits.
I will look into the GM performance parts and see if thats a viable option. The car is currently registered in Minnesota which has next to nothing for emmissions testing. "Does the car run"..."yes".. ok good, it passes. One thing I didn't think of, but no..I can't. the Q-Jet currently on the car has a heat activated choke...which none of the manifolds have the option for. Bummer. Anyway, thanks guys, I really do appreciate all this. Oh and Copandoc...yeah, this is going to be one fun ride when it's done. If you guys click on my gallary you will see the TA i'm working on.
Yup. You can even do it yourself with a junkyard choke. It just bolts up to the same spot. I like to solder the old heat tube hole closed to keep the proper temp inside.
I just looked into it and the GM Performance parts intake has provisions for both EGR AND a heat choke if I'm reading it right. The down side is that it's $100 more expensive than the others.
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| 4-71 with intake manifold and carb | chevyhotrod | Engine | 3 | 08-02-2005 01:22 AM |
| Spacer between carb and intake manifold?... | doc_rage | Hotrodding Basics | 2 | 02-06-2004 07:40 PM |
| Need some intake manifold help | killerformula | Engine | 14 | 11-29-2003 10:07 PM |
| intake manifold | 69cougar | Engine | 2 | 12-29-2002 04:37 PM |
