Intake Manifold Choice on 355 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2011, 07:00 PM
I am building a 355 I have 6" rods,73 cc heads, Comp Cam XE268,and just wondering if the Edelbrock Rpm Air Gap is my best choice?
Old 08-26-2011, 11:58 PM
techinspector1's Avatar
Wiki Edits: 326
In all the DynoSim programs I ran, a high-rise, dual-plane intake made the most power between idle and 6000. Here's a rundown on 'em. Air gap manifolds were not considered in this article....
http://www.crankshaftcoalition.com/w...e_manifold_SBC
Old 08-27-2011, 01:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The AG is slower to warm up, and it's biggest "advantage" over the non AG RPM is the cut down plenum divider. You can duplicate the cut down plenum divider on the regular RPM yourself if you choose to, plus save a few bucks in the process over the cost of the AG RPM.
Take a look at the video HERE. It compares the AG to the non AG, etc.
Old 09-02-2011, 03:55 PM
Thanks guys you were very helpful and after looking into it they are about the same. I have a guy melling my plenum as I type.
Old 09-02-2011, 04:30 PM
bentwings's Avatar
bentwings
I lived in Tenn for a while so I know how hot it gets there. Air Gap RPM's are fine a blistering hot day at full throttle. That's about it however. 99.---long decimal % of the time you are just cruising at part throttle. AG RPM's without heat riser ports simply run too cool to give proper fuel vaporization and distribution. The milled divider works fine but it is still cold blooded. Somewhere there was a side by side test and there is ony a few (like 7 hp) difference between the AG RPM and the standard RPM and only at the very top of the scale.
I have one and ran it briefly on my 355. It worked great after about 50 hours of messing with it and another $100 worth of squirters, jets, cams and secondary springs. It's sitting under the bench now having been replaced with a 6-71 and 2 750 dp that ran out of the box quite well. After an equal 50 hours of messing around I get better mileage and about 150 hp to boot. I couldn't imagin trying to run the air gap at 10 deg F. The blower works fine...about a pound more boost too.
Head and Intake Choice Ricer Eater 78 Engine 6 05-20-2011 03:59 PM
Engine build intake manifold choice Badazz93 Engine 4 02-28-2011 04:28 PM
Intake Manifold Choice? Please Help sb72elcamino350 Engine 3 06-04-2005 05:58 PM
O2 sensor bung placement/ manifold choice williambartram Engine 12 12-19-2004 12:31 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
