Intake manifold exhaust connection - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2008, 11:17 AM
I am fitting a Weiand Stealth intake to a 351W fitted with GT40 aluminum heads. There is an exhaust passage half way along each head mating surface which lines up with holes in the intake - should these be closed off by the gaskets, or left open? If there's a choice, what should I base the decision on?
Old 07-20-2008, 11:22 AM
SSedan64's Avatar
They're to help warm the intake in cold weather and keep the fuel from puddling. For a strip car I'd say block them off with the gaskets that have the metal piece made in them. If you use just gasket material it will burn through in no time.
Old 07-20-2008, 11:33 AM
It's a purely street car, - I don't have a problem keeping it warm! It has to sit in traffic a fair bit, so maybe better blocked off to stop overheating?
Old 07-20-2008, 11:46 AM
The UK is rarely hot, rarely real cold.
My initial reaction is to drill a 1/4 inch hole through each block off plate.
That aluminum intake will pull some heat from the lifter valley also.
Just a thought.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
1996 Ford 460 Exhaust Manifold Problem! Solution? BobnSofi Engine 0 05-10-2007 09:56 PM
help with a cam choice powerrodsmike Engine 24 07-30-2006 10:42 PM
Which intake manifold? WakBordr7387 Engine 13 12-10-2004 07:47 AM
