intake manifold gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2010, 10:16 AM
hemi joe's Avatar
loves ex cop cars
hey guys,i can't seem to find a intake gasket for my 1987 5.7L/350 sbc.I need a gasket with provisions for egr,everything i looked at does not have cut-outs for egr.Anyone have a suggestion on which gasket set i need.I just got an edelbrock performer intake and the gasket that they suggest(part# GM 10159409 is for tbi i have a quadrajet).thanks in advance joe.
Old 04-23-2010, 12:40 PM
DoubleVision's Avatar
http://www.summitracing.com/parts/FE...n/?prefilter=0
The EGR is fed by the heat riser passage in the heads, so this gasket should be the one you need since it`s open.
Old 04-23-2010, 01:22 PM
hemi joe's Avatar
loves ex cop cars
i have that gasket and the ports are blocked.
Old 04-23-2010, 03:59 PM
BOBCRMAN@aol.com's Avatar
I use a very simple solution. Fel Pro gaskets have the embossment for the EGR but no holes. Simply drill the holes with a 7/16 drill bit. Works everytime
Old 04-23-2010, 04:14 PM
hemi joe's Avatar
loves ex cop cars
now that sounds like a plan,thanks bob.
Intake manifold not sealing? Biscuit6447 Engine 13 10-02-2009 09:05 PM
Intake Manifold won't fit Andrew7dg Engine 18 12-15-2008 08:27 AM
Carb gasket dual plane intake to 4 BBL D. Newland Engine 3 09-26-2008 04:36 PM
which intake manifold gasket? leastbay Engine 22 11-09-2006 04:36 PM
Spacer between carb and intake manifold?... doc_rage Hotrodding Basics 2 02-06-2004 07:40 PM
