Intake manifold gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2011, 12:26 PM
Hi
I pulled of the intake today from my engine and noticed that a part of the gasket was ripped off you can see on the picture.
The middle "string" is gone.
Its first time that i noticed that in the blower intake the ports are not separated..
So there's no pressure to the "middle string" of the gasket...
And that shouldn't be good in my mind because then you have a constant leak between two ports... or maybe not?!?! Because there�s non separating wall...
Well i hope someone have some input..
Its a weiand 144 intake and world products sportsman II heads
Old 03-28-2011, 05:33 PM
DoubleVision's Avatar
Well,, if my eyes serve me right the manifold`s port is open and if it`s open why would it need a seal inbetween the ports? a 4.3 chevy V6 is designed this exact same way. It appears someone used standard intake gaskets and cut the center sections out which was a good idea as there was nothing to hold them in place which is a open invatation for them to go into a cylinder and cause all kinds of havoc
Old 03-28-2011, 05:38 PM
BOBCRMAN@aol.com's Avatar
The blower manifold is just a large open tub. Because the intake charge is pressurized most of the time. The need for runners is less of a factor.
I would trim away the gasket divider and run the manifold that way.
intake manifold gasket? hemi joe Engine 4 04-23-2010 04:14 PM
454 Intake Manifold Gasket ?'s Ignitrous Engine 3 12-06-2009 12:39 PM
Intake Manifold Gasket Installation - Help leejoy Engine 7 10-29-2007 07:19 PM
which intake manifold gasket? leastbay Engine 22 11-09-2006 04:36 PM
Which Intake Manifold Gasket? oregon chevelle Engine 10 04-18-2006 12:11 AM
