intake manifold gasket sugestion???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 09:05 PM
1996thunderchicken's Avatar
ALL AMERICAN MADE
ok i got a set of felpro intake gaskets they are the stock replacement style are these going to work on the edelbrock aluminum intake i have and should i put the exhaust cross over restrictor in or leave it out
Old 04-28-2012, 10:13 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If it's the stock replacement for your motor, and the intake is for your motor, it should work. As far as blocking the heat crossover, up to you, it will effect warm up time.
Semper Fi
Old 04-29-2012, 04:48 PM
ALL AMERICAN MADE
the reason i was wondering about this is because it is an aluminum edelbrock performer manifold and my heads are stock heads the engine is the the 250 hp engine its from jasper engine the years for my engine is 68-76 i still got the tickets from when the engine was bought for the car back in 1996 so i know its a good engine and also the date code on the intake is 1-22-96 but any way here is the part number from my intake gasket set its MS90314-2
its felpro gasket set i was wandering if this gasket set will doo good with the eddy intake i have
Intake manifold gasket LordTTK Engine 2 03-28-2011 05:38 PM
intake manifold gasket? hemi joe Engine 4 04-23-2010 04:14 PM
Intake Manifold Gasket Installation - Help leejoy Engine 7 10-29-2007 07:19 PM
which intake manifold gasket? leastbay Engine 22 11-09-2006 04:36 PM
Which Intake Manifold Gasket? oregon chevelle Engine 10 04-18-2006 12:11 AM
