intake manifold gaskets... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2002, 12:24 PM
Cool intake manifold gaskets...
I have an 87 camaro, v6 2.8 and my car blew the intake manifold gaskets and hasn't ran since. I'm gonna start working on the car this weekend, but I was wondering if new gaskets would make it run or if the engine would need rebuilt. Any info would be appreciated, thanks.
brandon
Old 08-25-2002, 01:20 PM
dmorris1200's Avatar
doesn't play well with others
Post
Well assuming your information supplied is correct and all you did was blow the intake gasket then you should be able to replace the intake gasket and be ok. Also not a bad idea to replace any other gaskets that you can while operating such as throttle body, valve cover gaskets if leaking, t-stat and gasket, etc.
BUILT FORD TOUGH
