Intake manifold gaskets for alum. heads and intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2003, 09:08 PM
mustang66maniac's Avatar
Ford Freak
Post Intake manifold gaskets for alum. heads and intake
No matter what i try, i still develop a vacuum leak. Is there a special gasket to use with edelbrock heads and intake???? So far I've tried stock gaskets with RTV smeared outside the ports, and the gaskets with the silicone rings on it.
Old 04-17-2003, 10:05 PM
chevypunk's Avatar
hungry cannibal, raving animal
Post
Well, im not the smartest engine guy around, but i always use fel-pro gaskets for everything, and on the front and back of the intake (where it meets the engine block) use The Right Stuff. its a silicone like gasket material that works great. its kinda expensive, but well worth the extra money. also check the torque on your bolts.
Good luck
Old 04-17-2003, 11:04 PM
4 Jaw Chuck's Avatar
Post
Non hardening sealer works far better than silicone in this application, I like this product best but any non-hardening sealant will work. I use this stuff for sealing motorcycle crankcases without gaskets so I know it works well in difficult to seal applications. Coat your gaskets in the stuff, I must warn you it is expensive for the amount you get in a tube. Get some primer T or N to go with it for the ultimate in sealing.
[ April 18, 2003: Message edited by: 4 Jaw Chuck ]</p>
— Han Solo
Old 04-18-2003, 04:27 AM
woodz428's Avatar
Troll Hunter
Arrow
I only use sealant around the water passages, most newer gaskets are silicone coated and any extra sealer can make them 'move". Another possibility is any machine work done on the block or heads could be making them not align as they are supposed to.
Old 04-18-2003, 07:12 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
With all joking aside this is not the correct place for tip of the day it should be put in the
Hotrodders' Lounge
A place to hang out and discuss non-automotive stuff. <img src="graemlins/nono.gif" border="0" alt="[nono]" />
Luv the smell of NITRO in the morning.
Old 02-20-2004, 12:03 PM
HJCHEVY400's Avatar
When Cool Meant Cubic Inches
Big 10 4
Old 02-20-2004, 12:19 PM
aka Duke of URL
Thumbs up
Agreed. You might want to run a machinists straight edge over the machined surfaces and make sure they are within tolerance.
Does't EDELBROCK have their own brand of gaskets? (I always use FEL-PRO)
