intake manifold help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2012, 10:14 PM
47Coop's Avatar
Can someone send me detailed instructions for putting an intake on my chevy 400 small block? Maybe your own opinion on products , torque pattern , how many pounds of torque, what kind of sealant, sealing the bolts etc ? I've never done it before and dont want to scew it up but i want to do it myself. Its the only way to learn. Its an Edelbrock Performer RPM . There was some cat on youtube doing it but he didnt look like he knew what he was doing. Makes two of us. Thanks.
Old 07-25-2012, 05:41 AM
The Edelbrock instructions are good, but there are a few other suggestions/reminders I have.
1 - Use the recommended Edelbrock gaskets (either their brand or Fel-Pro). The gaskets must be flexible enough to get a good seal, and some performance gaskets will not seal correctly.
2 - Don't use the end rubber pieces (if they are included); use a 1/4" high bead of oil resistant black RTV or equivalent instead. You may also put a very small amount of RTV around the water passage areas where the blue line of sealant is on the gasket.
3 - The inner bolt holes go into the lifter valley, so you need a small amount of sealant on the threads. You can very easily see which bolts when the manifold is off. If you don't seal them they will wick small amounts of oil up onto the manifold.
4 - The gasket set will include blocking plates for the exhaust crossover. The plates insert from each side of the gasket and you bend the small tabs to lock them together. Unless you have a hot air or divorced choke, you can block off the crossover.
6 - On my SBC I have to remove the valve covers to get clearance to replace the manifold.
7 - You may need some pipe-thread plugs for unused fittings in the manifold. The auto parts ones look better, but you can also get them at Lowes or Home Depot.
8 - Edelbrock instructions include the torque sequence. Some of the bolts near the carburetor pad are very hard to get at with a socket. You might have to use a box end wrench and estimate the torque.
9 - Use gask-a-cinch or some other spray on product to stick the gaskets on the heads while you install the manifold. Dry fit the manifold before you put on the RTV, and make sure everything lines up.
Once you set it in place with the bead of RTV, make sure the manifold is even (left to right) and the gasket has not shifted. Then install the bolts finger tight and make sure all the holes are still lined up. Torque in sequence.
Bruce
Old 07-25-2012, 08:28 AM
47Coop's Avatar
which sealant do i use for the bolts ? and thanks a lot !
Old 07-25-2012, 08:42 AM
Edelbrock Performer Rpm intake
You can print these instructions from Edelbrock's website: http://www.edelbrock.com/automotive_.../7000/7104.pdf. You can also use Fel-Pro perm-a-torque gaskets and use the Permatex black RTV sealer on the front and back. Be sure it is oil resistant. There is no need for any spray sealant with these gaskets. Torque the bolts in sequence to 25 lbs.
Old 07-25-2012, 08:45 PM
47Coop's Avatar
You may also put a very small amount of RTV around the water passage areas where the blue line of sealant is on the gasket.The gasket set will include blocking plates for the exhaust crossover. The plates insert from each side of the gasket and you bend the small tabs to lock them together. Unless you have a hot air or divorced choke, you can block off the crossover.
Not sure what you mean here. What is the water passage area ?
I dont have a blue line of sealant on the gasket. The gaskets are made by engine tech / fire seal.
Also , what is the exhaust crossover ? Forgive me for the lack of knowledge but I'm new to this. I've been a paint and body man my whole life. My heads have a square looking hole toward the rear of the engine but the intake does not have holes in this area. Is that what the blocking plates are for ? I only see one blocking plate. Looks like a thin piece of stainless .
Old 07-25-2012, 10:27 PM
47Coop's Avatar
Bruce
I think i got it. I put a little silicone (not much) around the water holes on the gasket , put a little on the inner bolts but not the 4 outside bolts. I used some of the permatex copper spray gasket just to hold them in place and that stuff didnt work worth a d--n. But putting the silicone around the water holes helped. The only problem that I had was the torque wrench would not fit bolts 1-4. The socket hit the intake so I had to guess on those bolts. I set the torque to 25 lbs and got the feel for it and then used and open end wrench and applied what i think was the same pressure. Sure hope it works.
edelbrock, intake manifold
intake manifold ssonny34 Engine 1 10-10-2009 09:55 PM
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 08:49 PM
Intake manifold fyrdup Engine 1 10-30-2005 08:07 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 12:19 PM
Need some intake manifold help killerformula Engine 14 11-29-2003 11:07 PM
