intake manifold leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2011, 06:01 PM
i have coolent leaking from a bolt should i use plummers tape or high temp silicone?
Old 03-04-2011, 06:05 PM
spinn's Avatar
Intake bolts that go through water passages should get some liquid teflon type sealant/ thread sealer. If no sealant was used prior to the leak, it might not seal. Has the engine heat cycled, and then not rechecked the bolts.
Old 03-04-2011, 10:19 PM
Leoman's Avatar
I've had oil leak through my center intake bolts; never had coolant come through any of them, but for either case either teflon sealer or permatex #3 tacky thread sealant will work fine (the #3 will only dissolve in alcohol, not glycol). But in my case, I just use plain old teflon tape. That works fine too; just be sure to replace it if you pull the bolt out for some reason.
Questionable intake manifold leak tommy evans Engine 5 08-09-2010 12:14 PM
Intake Manifold Oil Leak - Smallblock 327 Chevy 64Joker Engine 9 11-18-2009 06:41 PM
Leak on top of SBC 350 intake manifold 75gmck25 Engine 9 01-23-2009 09:11 AM
Can oil leak out of an intake manifold? leastbay Engine 11 08-12-2004 01:55 PM
can a leak on the intake manifold cause problem when my transmission shifts dopey Transmission - Rearend 7 08-01-2004 09:43 AM
