Intake manifold leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2012, 11:01 PM
V305's Avatar
On the Border
Hi guys, I'm trying to diagnose a problem, since last week my car started to have poor idle, poor mpg's and the exhaust smells too rich, and I noticed that the coolant overflow tank goes empty so every week I have to pour some coolant in there, the coolant problem started a month ago. I already tested for external vacuum leaks but I didnt found any, so I'm guessing it could be internal since I'm losing some coolant. What do you think?
PS: I havent done the internal leak test since I dont have a vacuum gage, but will do when I get one
Old 09-30-2012, 11:54 PM
DoubleVision's Avatar
If the intake had a leak it would be running leaner, not richer.
While it's possible coolant is leaking around the intake then some of it should be appearing in the oil.
The Following User Says Thank You to DoubleVision For This Useful Post:
V305 (10-01-2012)
Old 10-01-2012, 05:04 AM
If you are losing anti-freeze and it is not going on the ground, you have two choices. Pull the intake to check the gasket. If the intake gasket isn't leaking the only thing left is the head gaskets. Pull the oil dipstick does the oil look milky. I am thinking the intake gasket is leaking and your losing anti-freeze out through the exhaust. Check your plugs they should show if anti-freeze is leaking into the a cylinder.
The Following User Says Thank You to cdminter59 For This Useful Post:
V305 (10-01-2012)
Old 10-01-2012, 12:22 PM
V305's Avatar
On the Border
Thanks guys, I'm going to pull the intake any way, I've found a leak in the back of the block on the china wal near the dist. hole, the plugs from 5, 6 and 8 look oily, it's been 3 years since I installed that intake, I thought it would last longer.
intake manifold, intake manifold leak
oil leak at intake manifold 72ardosnova Engine 3 12-20-2011 05:30 PM
intake manifold leak dar timmons Engine 2 03-04-2011 11:19 PM
Questionable intake manifold leak tommy evans Engine 5 08-09-2010 01:14 PM
Can oil leak out of an intake manifold? leastbay Engine 11 08-12-2004 02:55 PM
can a leak on the intake manifold cause problem when my transmission shifts dopey Transmission - Rearend 7 08-01-2004 10:43 AM
