intake manifold is messed up, need help picking another - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2007, 02:54 AM
84Z 84Z is offline
Gas Raper
So I was loosening the thermo bolts and one broke, tried drilling and taping and it didnt work out as I planned so I tried epoxying a stud in place and it's slightly leaking right now. I'm fed up with it so I'm just going with a new manifold, but I'd like some suggestions.
My engine is a 409 sbc, 10.5:1 compression, Brodix T1X heads, Crower hydraulic roller cam 0.576 intake w/ 236 duration .564 exhaust w/ 244 duration and 114 separation, I have a 3.9 gear, 4500 stall, turbo 400 trans, 28" tires. It is my street car but I barely drive it so I dont care if it's hard to drive. I had a Weiand Stealth intake manifold on it before, but I was looking for a intake manifold with a 4-corner water boss system because I tend to overheat. Any suggestions?
Old 08-21-2007, 05:57 AM
DoubleVision's Avatar
I would think any intake along that line would work fine. The Edelbrock performer RPM, The Weiand Stealth, Performer RPM Air Gap, Stealth Air Strike, A Holley Street Dominator as well as a few others. I do not recommend any professional products intakes, while the price tag reflects a attractive buy, you get what you pay for, and the case in these intakes it`s made in china out of odd material junk. I have a weiand stealth intake for sale. The water neck holes do need to be heli coiled, but I can have that done or you could, whichever, it don`t cost much, around $7 a piece. The intake has been blasted in a machine and looks new and it has maybe about 20,000 miles of usage on it.
The heating issue could be caused by many things, and I doubt the 4 corner cooling will help it any. I would find out why it was overheating the way it is as many cars with engines just as hot as yours run cool on the street. I would think the 4500 stall has alot to do with it as the engine has to work in the upper rpm ranges to get the car moving so it gets hot. Many other factors could be causing it as well.
Altima GXE Intake Manifold Gasket awbazar Engine 5 01-24-2010 08:45 AM
Intake manifold volume techinspector1 Engine 8 07-13-2007 11:43 PM
Ebay Intake Manifold Speed7 Engine 4 03-17-2007 09:01 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Need some intake manifold help killerformula Engine 14 11-29-2003 11:07 PM
