Intake Manifold is my uncle crazy? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2012, 10:43 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I have a 350SBC with a XE274H cam (230/236 @ 050 and .490" lift) around 9.8:1 compression ratio and factory Vortec heads. I am guessing 375-400HP and 415 ft/lbs torque. Transmission is a 4 speed manual B/W Super T-10 and a 1981 Chevy C-10 pickup truck with a 3.71 posi rear end. This is a weekend fun truck, all performance street use. No racing, no drag strip, etc.
He is telling that dual plane intakes are for tall gears and automatics. And is trying to direct me use a Victor or Victor Jr. But the operating range of these single plane intakes are so high. I don't really plan to take the engine past 6,500 RPMs (and even then, that is going to be in an extreme Mustang killing situation!), so it seems crazy to have an intake capable of 8,000 RPM's! And lose the low end grunt needed to get this truck moving from the line.
I was looking at a dual plane Edlebrock Performer RPM intake which was like 1,500-6,500 RPM's and seems better suited for street use and my cam. Suggestions?
Old 05-14-2012, 11:20 AM
327NUT's Avatar
It's your engine and your decision ($$$$) but I would buy the Edelbrock Performer for your application. There's a ton of good used ones on ebay also.
Old 05-14-2012, 11:29 AM
I am not so much concerned about saving a few dollars on the intake, I want to use the best one.
Old 05-14-2012, 12:09 PM
Banned
The cam is a little too big for your application but a RPM intake would be the way to go.
Old 05-14-2012, 12:10 PM
Performer RPM AirGap
Old 05-14-2012, 12:11 PM
Dan
I personally would get the dual plane, better street use but still will have the performance youre looking for
Old 05-14-2012, 06:16 PM
Performer RPM AirGap.
Old 05-14-2012, 09:07 PM
cool rockin daddy's Avatar
Forget the Airgap. No real advantage and fuel icing has been a reported problem. Just go with the Performer RPM. You could do a forum search on here and find out exactly why a dual plane is considered better for the street and a single plane manifold is more for racing.
Old 05-15-2012, 12:51 AM
JeffB's Avatar
Weiand Stealth Intake.
Old 05-15-2012, 02:12 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
edelbrock intake?
dual plane for sure. i've always used airgaps. never had icing problems. but have had perculating problems with out them. if your using a holley carb. use a weiand intake. edelbrock located the vacuum port close to the carb flange in order for it to be easier for you to use their spreadbore carb rather than using the competitions double fuel bowl carb. i believe the weiand is cheaper as well
Old 05-15-2012, 06:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For a squarebore carb, Stealth p/n 8151 or RPM p/n 7116 (p/n's are for a natural finish). If more top end is wanted, cut the plenum divider like the RPM Air Gap or add a 1" open spacer if there's clearance.
Old 05-15-2012, 07:31 AM
bracketeer's Avatar
489 Lemans
spacer
If you have the hood clearance spacers can do wonders. I put a spacer on a victor jr. single plane and picked up .15 seconds. thats appx 15 hp
Old 05-15-2012, 09:06 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Whether a spacer helps or not depends on the engine setup. Some like more plenum and respond well to spacer, on some a spacer makes no difference, and on a few the spacer will actually hurt power. Cheap enough to try it though.
Definitely a dual plane intake if you're mainly street running. Dual planes keep charge velocity higher and that makes for better low end torque and keeps fuel suspended better at low speeds. Big open plenums work best at higher rpm, great for drag racing, not so great for street.
Old 05-15-2012, 09:32 AM
lg1969's Avatar
Google "Tunnel Ram 406"
I'm with you, Silver. go for it.
Old 05-15-2012, 02:16 PM
While I do appreciate everyone's input on what intake they suggest, I am really not interested in brands or models, at least just not yet. I need to decide on the type of intake and WHY. Yes I do know that people prefer the dual plane intakes for street because they have better torque at lower RPM's. But does anyone use single plane carb'd intakes off the track?
If anything I am leaning toward going with the single plane intake.
The reasons are three fold:
(1) The truck has no weight, or traction, or fat slicks in the rear end, so it tends to spin the wheels on launches. Perhaps the single plane would tame the torque down low and help the tires bite.
(2) It's a stick and you tend to shift at higher RPM's than an auto you would get the benefit of the single plane power more than you think.
(3) It is geared low so overall the RPM's would be higher during cruising and thus power would be available right now.
what intake manifold to use proge Engine 1 10-22-2008 01:31 AM
My intake manifold. TheBRAIN Hotrodding Basics 9 08-22-2006 11:16 PM
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 07:49 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
Intake Manifold fsiramps Engine 2 02-13-2003 05:26 AM
