Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - intake manifold from the Russian v8
  #17 (permalink)
Old 01-21-2012, 07:47 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Comrade, don't waste your time altering the manifold, just install a turbocharger and your engine will come alive big time, even with the small stock carburator, dont grind or file anything, just tune the carb and the ignition for the new boost pressurized engine.
do you guys have in Russia the Mercedes Benz diesel OM352 engines? you can use the turbocharger from this engine, it's the perfect size for most small block V8's and at least here is very cheap $450. if not, use any turbo from a Kamaz diesel truck.
