Intake Port Gasket matching Vortec Heads - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-06-2012, 04:59 PM
Banned
Originally Posted by Jkingof956 View Post
so now that I messed up on port maching with gasket am I now am forced to gasket matched my intake manifold???
no. just leave it as is.
  #17 (permalink)
Old 11-06-2012, 05:53 PM
oh ok i will do so thanks for the help
  #18 (permalink)
Old 11-06-2012, 09:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Like I said- only remove any mismatch as seen if you were looking from the intake runner towards the cylinder head intake port. If there's cylinder head showing where the manifold meets the head, remove it. Don't worry about the mismatch going from the head towards the intake manifold.
  #19 (permalink)
Old 11-07-2012, 02:16 PM
ok i will check that. also do i need to do some cleanup like deburring around the intake valve seat? just like i did to the exhaust ports or do i leave it as is and just do the exhaust ports?
  #20 (permalink)
Old 11-07-2012, 04:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There's usually an area (seen in the image below) that needs attention on all the valves (click on image below for a page on head porting). Just don't get into the valve seat or the machined angles approaching just above and below the seat if the heads have been given a three angle valve job.
Research where the short turn radius is located and leave that area alone.
Good luck.
  #21 (permalink)
Old 11-07-2012, 07:34 PM
vinniekq2's Avatar
the worst part of vortec heads is the exhaust flow ratio is terrible.The intake flows 230 plus cfm...If you can get the exhaust to flow 185 cfm then your engine will make very good power.You need a flow bench to check your flow.
port matching vs gasket matching? steveyb4342 Engine 2 04-07-2007 06:41 AM
Port matching intake 57NAPCO Engine 5 03-04-2005 10:10 AM
Intake port matching. Help please 67 Deuce 4 Me Engine 7 12-12-2004 04:40 PM
Intake port matching AFR heads 406chevelle Engine 2 01-16-2004 05:26 PM
port matching heads and intake nosliw721 Engine 1 12-23-2002 04:47 PM
